63 Fan Clutch Question - NCRS Discussion Boards
  • Thomas S.
    • February 7, 2016
    • 617
    The fan clutch on my 63 327/340 has markings on the mounting flange that might indicate it is incorrect. Amoung other markings appear 271 68, and 5329100. I beleive a correct clutch would not be dated for 63's. This one has an exposed coil and is stamped with a Delco brand. If it's not correct for 63 there's no point in having it restored.
    Comments appreciated.
    Tom
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
  • Thomas S.
    • February 7, 2016
    • 617
    Tom
    • Harry S.
      • July 31, 2002
      • 5295
      Re: 63 Fan Clutch Question
      I believe this to be a 63......
      • Larry M.
        • January 1, 1992
        • 2688
        It is not correct for a 1963 car. It is a later service replacement. It still may have some value to someone with a C3 car.
        Larry
        • Tom P.
          • February 1, 1982
          • 69
          One of the few pieces I still have left from my November 62 car is the clutch fan. It doesn't have the exposed spring like Harry posted so I suspect that there may be variations depending on when the car was produced. I think early cars may have gotten Eaton units?
          • Larry M.
            • January 1, 1992
            • 2688
            Both Eaton and Schwitzer fan clutches were used in production. The Eaton is still available as a service replacement. K&B recently started reproducing the Schweitzer design. It is a very nice unit, although it does not have all the original numbers and logos.
            OP's best bet for a good original is to contact the 2-3 current rebuilders and see if they have a completed and date correct unit for sale. Otherwise buy a correct core and have it rebuilt.
            Larry
            • Frank D.
              • December 27, 2007
              • 2703
              Larry
              I used a repro Schwitzer for the regional judging of my '63 250hp car. It is indeed a nice repro and did well and works well too.
              In retrospect I might have put some clear coat over the stenciling on the front of the fan as that text faded quite quickly to almost invisibility, but I didn't know if doing that would affect its operation...
              These folks rebuild the clutches but I don't know if they have any original pieces on hand: http://www.kirkconnellcorvettes.com/
              • David L.
                • July 31, 1980
                • 3310
                GM # 5329100 appears in the 1968, 1969, and 19780 Corvette assembly manual as an optional fan clutch. The "271 68" stamping is a date code (271st day of 1971). I do not have a 1972 Corvette AIM.
                Dave
                • David L.
                  • July 31, 1980
                  • 3310
                  Here is a photo of a Eaton fan clutch ink stamped "E11F" and is dated May 11, 1965.
                  Harry's fan clutch ink stamped "C8D" is dated March 8, 1963.
                  Dave
                  • David L.
                    • July 31, 1980
                    • 3310
                    Harry,
                    "C8D" = March 8, 1963
                    Dave
                    • Thomas S.
                      • February 7, 2016
                      • 617
                      Thanks for all the comments and clarifications. I ended up getting a correct core from David Sokolowski and will have it rebuilt by pamperedcorvettes.
