70 power steering pump nut finish - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    What is the finish for the nut on the power steering bracket on a 70 sb. This is the nut that is used to fasten the pump to the bracket once adjusted for belt tension.
    Thank you,
    Bill
    • 43277
    Re: 70 power steering pump nut finish
    Thank you,
    Bill
    Bill------
    Zinc plated.
    • Bill L.
      • February 1, 2004
      • 1403
      Bill------
      Zinc plated.
      Thank you Joe.
      Thought so but also remember that not many nuts were zinc plated.
      Bill
        • 43277
        Thank you Joe.
        Bill
        Bill------
        Yes, many nuts and bolts used on Corvettes were of "plain" finish and many others were black phosphate-finished. However, nuts and bolts that were part of an "adjustment system", as in this case, were usually zinc plated.
        • Bill L.
          • February 1, 2004
          • 1403
          Bill------
          Makes complete sense Joe.
          Thank you again.
          Bill
