Re: Front and Rear End rebuild - Help, Tom Parsons! You're my only hope!
Hi Ian, do you think the first shaft was just out of spec?
20 seems a bit light. I am not at the house right now but I believe I found something with a spec for chassis fasteners at 50 - 80 ft lbs and control arm bushings at 85 ft lbs. The knuckle bolt on the spindle support is at 125 -135 ft lbs. I think I found this in the 62 passenger car service manual.
Glad to see you have all that worked out. When I installed the spindle supports I pre-fitted all the bolts and shafts just to make sure all lined up before compressing the springs.
I guessed at about 20 lbs, but since I'll be driving this thing I'd rather not guess
