'62 Taillight Cones/Protectors - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    Anybody care to share their secrets on how to keep these things on?
  • Mike E.
    • February 28, 1975
    • 5141
    Re: '62 Taillight Cones/Protectors
    Don't drive or touch the car in any way and you'll be fine.
    • Frank D.
      • December 27, 2007
      • 2703
      Ha! Correct answer.
      I've used a pinch of dum-dum at two spots on the inside of each one to try to secure them....it works OK.
      Loose stuff in the trunk knocking them around is to be avoided...
      • David R.
        • June 29, 2014
        • 183
        After many, many times of replacing them after one or more fell off, I decided that a more permanent solution was to (A) First make certain that all wiring connections were correct and secure, and then (B) Apply a VERY SMALL amount of clear silicone adhesive caulk to the post and slide them on. This has worked well for about 2 years now and is nearly undetectable if done neatly. Works for me.
        • Christopher R.
          • March 31, 1975
          • 1599
          Thank you gentlemen for your suggestions. I'm going to try them both. Frank, where'd you put the dum-dum?
          • Frank D.
            • December 27, 2007
            • 2703
            I put it on the inside of the cones (so as not to be seen) in different places...under the spot at the tail light mounting screw and then directly opposite and in other places on some cones where it looked like the stuff would get a 'bite'. The clear silicone is not a bad idea either (just didn't think of it). I tried some rubber plugs over the tail light screws to hold the cones but not enough screw exposed to make that work...
            • David R.
              • June 29, 2014
              • 183
              Yeah, I thought that rubber plugs would be the right way to go, too . . . until I found out the same thing you did, Frank. Just not enough exposed thread to grab on to. Oh, well. Between the silicone & the dum-dum (or maybe both), hopefully Christopher's problem is solved.
