1967 Holley 3810 help needed - NCRS Discussion Boards
  • Leif A.
    • August 31, 1997
    • 3630
    Re: 1967 Holley 3810 help needed
    Originally posted by Donald Olson (17357)
    Fixed.
    Took the carb off and tweak bent the rod, as described in the service manuals (both GM and Holley).
    I remember tweak bending the rod after I got this carb as the choke rod was binding against the main body. I guess I had over tweaked it.
    Don
    Don,
    Glad you solved the issue and thanks for reporting back with results.
    Leif
