1967 Holley 3810 help needed - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1593
    I'm having a problem with a choke operation rod. See attached pix number 1.
    I can re-attach it but after a couple of starts it comes out of its need attaching point and gives an idle speed of 1500 or so. See the circled area with the small red "X"s. I then have to go under the hood again and make sure its free for an idle of 800.
    I have a small "E" clip I may use (AA battery for scale), see pix number 2.....if all else fails.
    Don
    Pix no. 1
    Pix no. 2
  • Bill C.
    • July 15, 2007
    • 904
    Re: 1967 Holley 3810 help needed
    don -
    i think there should be a nylon type bushing that the rod goes down through (up top by the air horn)
    if thats missing or worn out, it will let the rod swing back and come out of the hole.
    but not an expert.....
    • Ralph E.
      • February 1, 2002
      • 905
      Don, I have the same carb and set up. I just went out to the garage and checked. It appears the end at the "X" is larger than the hole and the rod will not pass thru like yours does.
      Think the easiest fix for you is the "E" pin or a clamp similar retainer which hold the choke rod.
      • Donald O.
        • May 31, 1990
        • 1593
        Originally posted by Bill Chamberlain (47576)
        don -
        Bill,
        that bushing is there.
        Don
        • Donald O.
          • May 31, 1990
          • 1593
          don -
          Originally posted by Donald Olson (17357)
          Bill,
          Don
          Should that bushing "float" or should it be set into a single position?
          Don
          • Leif A.
            • August 31, 1997
            • 3645
            Don,
            I think it is a "bend" fix. I looked at my 3810 and that lower pin does float in and almost out of the lower hole. Also, looked at a 3810 service replacement and it is the same. Is it possible to gently bend the lower half of the rod more towards the hole so that the rod can't float backwards and fall out? Possibly attempting to bend out (towards the passenger fender) from the 15 degree bend halfway down the shaft. Hopefully, one of the carb guys who rebuilds these Holleys will chime in.
            Leif
            • Ralph E.
              • February 1, 2002
              • 905
              Looking at the rod again, I think Leif has the right idea. Can you bend the rod slightly as Leif explained?
              Again, it looks like my set up as well. Maybe somehow you changed the geometry?
              • Bill C.
                • July 15, 2007
                • 904
                Don
                The bushing in my carb is fixed and does not float around
                Bill
                • Donald O.
                  • May 31, 1990
                  • 1593
                  I guess I'll take it off and work on it on a bench instead of leaning over the fender and get a sore back.
                  Good thing I have a NOS mounting gasket to use.
                  What it the mounting torque for the 4 attaching nuts that secure the carb to the int mfld?
                  • Bill C.
                    • July 15, 2007
                    • 904
                    don,
                    not 100% sure, but I have always done 20# on all four and its has worked fine.
                    you need just enough to compress the gasket and get the base plate even.
                    you for sure don't want to over tighten, you could warp or crack an ear.
                    bill
                    • Timothy B.
                      • April 30, 1983
                      • 5196
                      Is it possible that rod is upside down?
                      • Leif A.
                        • August 31, 1997
                        • 3645
                        Tim,
                        Though the OP photo does not show the top of the rod in its' entirety, it has a completely different bend on the top...so, it's installed correctly.
                        Leif
                        • Leif A.
                          • August 31, 1997
                          • 3645
                          Don,
                          I typically tighten the four nuts down finger tight and then just a quarter turn more with a wrench/socket. As Bill mentioned, you certainly don't want to warp the base or crack a flange.
                          Leif
                          • Bill C.
                            • July 15, 2007
                            • 904
                            • Donald O.
                              • May 31, 1990
                              • 1593
                              Fixed.
                              Took the carb off and tweak bent the rod, as described in the service manuals (both GM and Holley).
                              I remember tweak bending the rod after I got this carb as the choke rod was binding against the main body. I guess I had over tweaked it.
                              Don
