Exhaust Pipes For 70 LT1 - NCRS Discussion Boards
  • Jack B.
    Infrequent User
    • November 1, 1982
    • 24
    Can any one give me a recommendation as to where I can purchase the best fitting exhaust system. I have had trouble in the past on other corvette's. Seems like they always need to be worked on in order to get them to fit the car. And never line up as they should. I have a set of Nos mufflers so all I need is the pipes from manifold's to mufflers. Thanks
  • Mike F.
    • April 25, 2011
    • 668
    Re: Exhaust Pipes For 70 LT1
    I bought a set from Gardner Exhaust, bolted up without any problems.
    • Patrick B.
      • August 31, 1985
      • 2003
      I don't think Gardner will sell pipes separately.
      • Jack B.
        Infrequent User
        • November 1, 1982
        • 24
        I checked with Gardner and thats correct, I would have to buy the mufflers with the pipes. Thanks for the help.
        • Gary R.
          • April 1, 1989
          • 1799
          I have used exhaust from a few places over the years, including a highly recommended mfg, and had fitment issues with most. The chambered exhaust I purchased from that place was no where near close to fitting and I had to have an exhaust shop refit the whole system.
          There was a guy named Jack Horner from TN who had an vette exhaust business and I met him at Carlisle years ago. I don't know if Jack is still in business or around anymore. I tried calling a couple of years ago but never got an answer, but his pipes fit like a glove and were reasonably priced. I am just sorry I didn't get a complete set for my 72 when I could.
          Maybe someone here knows Jack and can elaborate on it some more? Otherwise I would check into local custom shops so you can tell them what you want and can see it up in the air.
          • Ralph S.
            • February 1, 1985
            • 935
            I bought a complete system for a 1970 LT-1 in the middle 70's from my local Chevrolet Dealer it is sitting in my bedroom closet.
            • Terry L.
              • August 13, 2007
              • 99
              Jack,
              I bought the Gardner Exhaust also for my LT1 with no issues.
              • Jeffrey S.
                • May 31, 1988
                • 1890
                I just installed a complete welded exhaust system on a '70 small block yesterday. It was purchased from Corvette Central. Once the old system was removed, it took all of 30 minutes to do the install. No adjustment beyond simple alignment of the tips and rotating the rear section to get pipes close to rear end. Perfect fit right out of the box! Very impressed and would definitely recommend. I have absolutely no connection wit CC- just happy to see a well made/fitting part.
                Jeff
                • Mark D.
                  1984-96 Team Leader
                  • June 30, 1988
                  • 2157
                  So...how many emails have you received since you posted:-))
                  Kramden
                  • Bob J.
                    • December 1, 1977
                    • 716
                    Exact same thing I was thinking.
                    • Jack B.
                      Infrequent User
                      • November 1, 1982
                      • 24
                      I have got a lot of help from you guys. Thanks for all the good input. Jack
                      • Mark E.
                        • April 1, 1993
                        • 4602
                        You must be single.
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                          • 11668
                          For driving or for judging?
                          If I were going for judging and maximum points, I would buy a carbon steel system from Gardner's and use the NOS mufflers. The right person can skillfully mate the NOS mufflers to the Gardner pipes, and it will look so close to original it's amazing. I've seen a system like this. However, I would then remove it if I expected to drive the car post-judging.
                          If you're driving the car, just buy a welded aluminized set from Corvette Central. Much less expensive and also lasts a very long time.
                          • Ralph S.
                            • February 1, 1985
                            • 935
                            I want to advertise the GM system for sale in the Driveline any ideas as to what it is worth ?
                            • Michael J.
                              • January 27, 2009
                              • 7145
                              Not sure about C3 stuff, but an NOS set of N11 (Off road exhaust) for a C2 runs $1000-$1200.
