Hood Pull Broke - NCRS Discussion Boards
Hood Pull Broke
  • Jimmy G.
    • November 1, 1979
    • 977
    Hood Pull Broke
    1967 327 A/C Hood pull broken under the dash --- pulled loose at the lock I think
    What is the best was to open the hood???
  • Robert B.
    • March 1, 1992
    • 265
    Re: Hood Pull Broke
    if u have a lift this a little easier to accomplish, but I was able to get something (a long rod of some sort) up under and push against the mechanism that the rod connects to and unlock the hood. Good luck
    • Ken R.
      • August 31, 1980
      • 308
      Re: Hood Pull Broke
      look at this thread just below yours
      https://www.forums.ncrs.org/showthre...n-release-help
      • Gary J.
        • April 1, 1980
        • 1244
        Re: Hood Pull Broke
        Jimmy you may can remove the big splash shield for more access on the drivers side. The cable probably pulled through the barrel nut.
        • Ralph E.
          • February 1, 2002
          • 905
          Re: Hood Pull Broke
          Dave Zuberer has a fix. Sorry I do not know how to attach his .pdf
          Look up Dave Zuberer stuck passenger latch. His .pdf will help.
          • Leif A.
            • August 31, 1997
            • 3645
            Re: Hood Pull Broke
            Post #3 has a URL that will take you to a post I had on the CF. In that thread, post #8 has the Dave Zuberer PDF.
            Leif
            • Joe R.
              • July 31, 1976
              • 4551
              Re: Hood Pull Broke
              Jimmy,
              I'm sure it's the handle and cable!!!!! Your in luck cause I have an NOS handle assembly for a 1967. It's really for a 1967 BB 435HP but I'm sure it will work on your 1967 OK! Since its for a 435HP and its NOS its cost is $500.00 plus shipping. I take Paypal and all major credit cards. When do you want me to ship as I have your address.
              I'm sure Joe (not for sale) Lucia has one on the shelf but this one is for sale today!
              Anxiously awaiting your call!
              If we were not old friends I could not offer this NOS part at such a reduced price. After all its for a 67 435HP Corvette.
              JR
              PS. Please no response from experts! I'm just trying to help an old friend.
              • David Z.
                • April 1, 2002
                • 182
                Re: Hood Pull Broke
                Here is the PDF in question. Hope it helps a bit.
                Dave Z
                Dave Zuberer
                • Mark E.
                  • April 1, 1993
                  • 4602
                  Re: Hood Pull Broke
                  It seems the C2 guys have a PDF or YouTube for every problem.
                  What can the less fortunate C3 owners do when this happens?
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Al R.
                    • June 30, 1988
                    • 688
                    Re: Hood Pull Broke
                    Trade the C3 in for a C2 (a real corvette)
                    • Joe R.
                      • July 31, 1976
                      • 4551
                      Re: Hood Pull Broke
                      Amen and Amen!
                      JR
                      • Daniel S.
                        • February 1, 2000
                        • 164
                        Re: Hood Pull Broke
                        No need to trade your C3 in for and old C2. Solution --> http://www.capitalcorvetteclub.ca/in...-stuck-shut-c3
                        • Ed S.
                          • August 6, 2014
                          • 1377
                          Re: Hood Pull Broke
                          Perhaps it is because everything on a C2 at one time or another has been or is a problem - speaking with some experience here but wouldn't get rid of my C2 for anything.
                          Ed
                            • 43248
                            Re: Hood Pull Broke
                            Mark------
                            For a 1968-76 there's a way to prevent this problem from ever occurring and, at the same time, making hood release a smoother, easier operation. To do this, purchase an NOS GM #14030127 or a reproduction of the 1980-82 hood release assembly. These assemblies use a STRANDED release cable in contrast to the monofilament cable used for 1968-76. Remove the cable and handle assembly from the bracket/sheath assembly and insert it into the existing bracket/sheath assembly (this not only preserves the existing wire-wound sheath but also makes the repair MUCH easier as removing and re-installing a new bracket/sheath assembly is difficult). Then, insert the stranded cable into the hood latch release and install TWO GM #14030136 retainers ("barrel nuts") or equivalent to retain the cable. If you want to get real anal about it, you can install a GM #14030128 retainer (crimp-on) as a "tertiary" back-up. Do all this and concerns about hood release cable breakage (most likely occurring at the most inopportune time) are gone FOREVER.
                            The original release cables for C2 and 1968-76 Corvettes were a MONOFILAMENT-type cable. These work-harden and break. They also often make for a "hard pull" (which only increases the chance for breakage at some point).
                            Does this sacrifice originality for 1968-76 Corvettes? Of course! In this case, originality be damned. In actuality, the visible elements of this "mod" are quite minor.
                            • Mark E.
                              • April 1, 1993
                              • 4602
                              Re: Hood Pull Broke
                              Thanks Joe. This is one of those tips that should be a sticky somewhere.
                              Your post does beg the question about 1977-79. What do they use? Also, would these parts work for mid-years?
                              Mark Edmondson
                              Dallas, Texas
                              Texas Chapter
