Restoring center console plate on 65 - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7070
    Re: Restoring center console plate on 65
    Kurt,
    I suspect Richard plans to silk screen them, like he does with air cleaner lids. That' give the lettering a raised texture.
    Gary
    • R N.
      • May 31, 2002
      • 640
      Originally posted by Gary Beaupre (28818)
      Kurt,
      Gary
      Gary, I believe originals are embossed (or "recessed") slightly from the surrounding surface. This is one sure way to know if the plate is original or not as you can feel it as you run your finger tips over the shift pattern. Richard uses a wire EDM machine to do this.
      Reproduction pieces are printed on top the plate and are slightly raised from the surface.
      • Enzo C.
        • January 12, 2012
        • 536
        #18
        Hi Kurt, you are correct with your description... I have collected many shift patterns during my restoration ... My final decision was to use an original piece after I gave it a light buffing. It's not perfect but looks the est in my opinion .. Good luck with yours
        Enzo Colosimo
        Ncrs Ontario Chapter Chairman 🇨🇦
        ENZ-Z06/67
