1974 Astro side glass - NCRS Discussion Boards
  • James E.
    • April 1, 1988
    • 26
    Does anyone know about when in 1974, the use of the Astro Ventilation side glass stopped?
  • Jimmy P.
    • June 24, 2014
    • 1695
    Re: 1974 Astro side glass
    James,
    I believe it was toward the end of the 1974 model run that they stopped using the script on the glass.
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
    • James E.
      • April 1, 1988
      • 26
      I was looking at a late June 74 build date coupe, & it didn't have Astro glass. It's a 30k mile car, the glass is LOF & looks original. Any thoughts.
      • Jimmy P.
        • June 24, 2014
        • 1695
        James,
        That could be correct because it's a June car. That late 74 's didn't have the "Astro Script" on the Windows. Did you check the date code on the glass? BTW I edited my previous post. I'm sure other late 74 owners will chime in. Maybe Joel Adams, I think he has June 74 coupe.
        Jimmy
        1973 Convertible
        L48,M20,N40
        • James E.
          • April 1, 1988
          • 26
          Thank you for the help Jimmy. Have any idea what the app. vin # for the cut off would have been?
          • Jimmy P.
            • June 24, 2014
            • 1695
            No James, I'm not sure on that. I can however tell you that the last VIN # in May of 74 was 29602 and the last VIN # in June of 74 was 33257 according to the TIM&JG. Does the car have AC? Don' t think the cars had Astro Vent if they had AC. The rear vents were blocked off.
            This is where it gets confusing. The 73-74 TIM&JG says that most all 74's had Astro glass, but some real late models did not. Yours would be a late model because of the June build date. The 75-77 TIM&JG says that early 75 coupes /verts and very late 75 verts have been seen with Astro glass.
            Not sure if the helps or not..
            But im pretty sure that the June car you are looking at wouldn't have Astro glass.
            Jim
            Jimmy
            1973 Convertible
            L48,M20,N40
            • Robert R.
              • May 31, 1975
              • 358
              Jim,
              Whether a car came with AC or not, the Astro Vent script appeared on the side glass. The elimination was probably a cost cutting decision.
              Both of my '73s, coupe and convertible, both had / have AC, and both with the Astro script.
              • Joel A.
                • September 30, 1997
                • 214
                My '74 is a June 27 build(33177 vin), all original St. Louis installed glass, no Astro vent script, with A/C. I have seen some early '75s with the Astro vent script tho. No clue WHEN, or what VIN break the change took place.
                Joel Adams
                1974 Coupe
                1985 Coupe
                "I know the voices aren't real...but sometimes they have some really kewl ideas...."
                • John M.
                  Infrequent User
                  • February 25, 2008
                  • 16
                  My June 1st built car has astro glass and ac.
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    The key in judging is the date code on the glass. If that's acceptable, the presence of the astro ventilation script is secondary.
                    • James E.
                      • April 1, 1988
                      • 26
                      Thank you everyone for the info.
                      • Thomas S.
                        • April 7, 2008
                        • 17
                        My 74 Coupe has a build date of May 23 and has A/C and Astro script on the windows. The A/C cars have the rear vents plugged.
                        • James E.
                          • April 1, 1988
                          • 26
                          My 74 coupe with a/c, June 29 build no Astro glass.
