Drive Gear - NCRS Discussion Boards
Drive Gear
  • Paul S.
    • October 29, 2014
    • 16
    Drive Gear
    Does any one know where I can buy a drive gear for a '70 Muncie M 21? d It is an 8 tooth 1.760 O.D. with a 1.175 I.D. Thanks, Paul
  • Mark E.
    • April 1, 1993
    • 4607
    Re: Drive Gear
    These guys have just about everything for a Muncie:
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
      • 43279
      Re: Drive Gear
      Paul-------
      This is a NYLON gear originally of GM #3924097 and later GM #6261795. The latter was discontinued by GM without supersession more than 35 years ago. This gear is retained to the mainshaft by a small metal clip of GM #1373122.
      You can probably obtain this gear in reproduction from the source that Mark suggests or, if not, other sources.
      By the way, this gear was used only on a small number of 1970 Corvettes---those with a rear gear ration of 3.70:1 or numerically higher and using speedometer DRIVEN gears of 22 tooth (green) to 25 tooth count.
