a neat product for your shop - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8381
    Kimball Midwest Ultra-cut Gold Stick. this product is used to lubricate drill bits and taps. it significantly lengthens the life of these cutting tools as well as speeding up the cutting process itself. . its a wax-like product, part # 80-968.one just jabs the bit or tap into the jar it comes in. not expensive. mike
  • William F.
    • June 9, 2009
    • 1363
    Re: a neat product for your shop
    Any better than the old trick of putting bar soap on a drill bit?
      • 11643
      Mike, did you order it direct from them or buy it local to you?
      Patrick
      • Mike M.
        • May 31, 1974
        • 8381
        the kimbell midwest salesman come by my shop monthly. i don't know if one can order directly from the co. regards,mike
        • Kenneth B.
          • August 31, 1984
          • 2087
          I like Tap Magic for drilling & especially taping. They make one for aluminum & one for steel. I would NEVER tap these metals with out some lubrication. CI is drilled & taped dry. You can buy it in small containers that look like a oil can.
          • Domenic T.
            • January 29, 2010
            • 2452
            Mike,
            I'll give it a try. I have different cutting oils and find that bacon fat works great also, AND smells good. makes ya hungry.
            Dom
            • David G.
              • May 31, 1980
              • 275
              Originally posted by Domenic Tallarita (51287)
              Mike,
              Dom
              Mike
              if you use bacon oil, don't forget to get a double order.
              • Mike M.
                • May 31, 1974
                • 8381
                funny u should mention bacon grease. i got a mess of w va ramps the other day, fried a lb of kusler bacon, then fried some potaoes in the bacon grease, along with the ramps. only griese's bologna can top the ramp mix.
