70 LT1 Radiator support - NCRS Discussion Boards
  • James S.
    • August 21, 2013
    • 53
    I'm needing a radiator support for my 70 LT1 and most of my books do not list one. I have a 27 inch copper radiator and no a/c. From pictures a big block car looks to have the same support and shroud.
  • Joe R.
    • July 31, 1976
    • 4550
    Re: 70 LT1 Radiator support
    James,
    Most parts houses list your radiator support as 69-72 with either 26.5 inches between saddle mounts or 27.5 inches between saddle mounts. Yours is a brass/copper radiator with saddle mounts or should be. Measure between saddle mounts (radiator cradles) and order from any parts house.
    JR
      • 3415
      Hi James,
      I don't know if you're looking for a used original or a reproduction?
      For the latter you might check with Coffman Corvette. I continue to see their ads for radiator supports in the Driveline.
        • 11643
        Paragon part #2350
        https://www.paragoncorvette.com/p-35...e-support.aspx
        I'm sure that other parts houses sell the same item as JR mentions.
        As Alan noted Coffman manufactures these, and they are generally of very high quality. I used one in a 1976 a year ago, and it dropped right in place.
          • 43218
          James-------
          69-72 big block cars DO NOT use the same support and shroud as LT-1. They might appear to be the same but they're definitely not.
          • Mark E.
            • April 1, 1993
            • 4536
            I installed a reproduction radiator support from http://www.coffmancorvette.com for my '70 LS5. It looked identical to the original (except for the rust) and fit perfectly. They are the supplier to the better parts houses, but you can order direct from them as well. I ordered direct because I asked them to not paint it and not attach the radiator's saddle brackets so I could locate them exactly where needed (each radiator, especially if re-cored, varies in width just a bit, which defines the location needed for the brackets).
            They were responsive and customer oriented. Manufacturing, support, and sales are in Mansfield, Ohio.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • James S.
              • August 21, 2013
              • 53
              Thanks guys just trying to keep it right. I appreciate all the help.
