1967 Roadster Arm Rest screws - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2586
    I tried a few searches, but didn't find this.
    The arm rest screws are missing on my 67 roadster. Paragon sells a 2" Phillip's machine thread screw with a fillister head. Long Island sells a sheet metal screw with a pan head and washer.
    I'm thinking one or the other should be correct, but not both! Which is correct?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Donald H.
    • November 2, 2009
    • 2586
    Re: 1967 Roadster Arm Rest screws
    Here are pictures from their catalogs. Paragon on the left and LIC on the right.
    Don Harris
      • 43247
      [ATTACH=CONFIG]69852[/ATTACH] [ATTACH=CONFIG]69853[/ATTACH]
      Don-----
      The original screws were GM #9420791. Unfortunately, I have no information on these screws as, as far as I can tell, they were never available in SERVICE. However, I can offer this tip: if the screws thread into a conventional nut (like a weld nut), then you need a machine screw. In that case, I would expect the machine screws are what you need and are, presumably, correct. However, if the screws thread into a sheet metal panel or a panel nut (J-nut), then the sheet metal screws are what you need and are, presumably, correct.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        I recently worked on 1967 door panels and what appeared original on this car were the Phillips head sheet metal screw type with flat washers.
        A quick check of the screw plate info at hand, states that the 1963 to 1966 type may be the Machine Screw type.
        1963-1966 appears to have spot welded machine threaded T-Nuts
        Whereas the 1967 version is shown as a plate without T-Nuts, but with a swedged area likely to have more surface area for the sheet metal type screw to grasp.
        • Bill L.
          • April 1, 1985
          • 349
          Expanding on the plate info that Rich provided.... page G140 of the '67 AIM indicates a "screw" [4] and "washer' [5] that seat into a "plate assembly" [7]----on my '67 the screws are sheet metal type philips head about 2 inches long....and a flat washer --- flat because it presses up against the soft door panel material ------
          For what its worth both my '66 Bowtie Coupe and my '67 coupe use sheet metal phillips head screws with flat washers ---
          Hope this helps....
          Regards
          Bill
          • Donald H.
            • November 2, 2009
            • 2586
            Thanks Rich and Bill, I'll order the sheet metal type.
            Don Harris
