1965 coupe upper corner stainless windshield trim - NCRS Discussion Boards
  • Mark W.
    Infrequent User
    • December 1, 1994
    • 4
    On my 65 coupe the c shaped upper corner stainless pieces fit perfectly but will not stay in place. When I push them down with my finger they are perfect but pop up a little with no pressure added. The goop by the clips is very dry and the clips have no rust. What is the hot ticket for holding these down. Thank you.
  • Ken R.
    • August 31, 1980
    • 308
    Re: 1965 coupe upper corner stainless windshield trim
    As I remember from my experience, the edges are rolled a bit to fit over the connecting 2 pieces. Your edges must be "spread" a bit. You shouldn't be able to actually press the parts together. You can try reforming the edges with some pressure against some sort of metal edge as I remember my doing a long, long time ago.
