67 roadster deck lid striker - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    How do I rivet the rear deck lid striker plate on a 67 roadster?
    Thank you,
    Randy
  • Daniel E.
    • April 30, 2005
    • 145
    Re: 67 roadster deck lid striker
    Randy,
    I use this slightly modified riveting tool and a bucking bar to replace them.
    • Jim S.
      • March 1, 1986
      • 1402
      As that is a delicate and difficult area , I was instructed to just J B Weld the three rivets into place to hold the striker .
      Works so far !
      Jim
        Thank you,
        Randy
        Randy -
        That stainless wear plate was designed to be riveted (with semi-tubular stainless rivets) in the rabbet area of the gutter way back in the off-line rear clip bonding fixture.
        • Daniel E.
          • April 30, 2005
          • 145
          John,
          You said the "wear plate was designed to be riveted (with semi-tubular stainless rivets)", were they ever actually installed that way? I have only ever seen them installed with solid aluminum rivets (at least that is what they appear to be).
          Daniel
          • John F.
            • August 31, 1998
            • 110
            Has anyone used the Aero Rivet tool to attach the deck lid striker? I was wondering if it fits. It looks like it could work on the two side rivets but not sure about the upper rivet.
            John
