63 Keys Configuration - NCRS Discussion Boards
  • Enzo C.
    • January 11, 2012
    • 534
    Hello 63 Enthusiasts ... Can someone tell me what keys and how many keys are needed ....for ignition,doors,glove box and spare tire lock .... Many Thanks
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
  • Don H.
    Moderator
    • June 16, 2009
    • 2239
    Re: 63 Keys Configuration
    hi Enzo
    one hex key and a spare, opens all locks.
    • Frank D.
      • December 26, 2007
      • 2703
      And a competent locksmith can reset any of those locks to work with the single key.
      When I bought an original spare tire tub lock my local locksmith set it up to work with my existing key.
      • Peter L.
        • May 31, 1983
        • 1930
        Enzo - Originally the 1963 Corvettes came with 2 identical GM/Briggs & Stratton logo octagon head keys, so one key fit & operated all the locks on the car. This was a the case for Corvettes produced thru 1964 production. Pete
        • Alan D.
          • December 31, 2004
          • 2030
          And while you are getting the key correct double check the operation of the ignition switch. It does not take much use for it to operate incorrectly.
          Mine was bad in 1967 (64 car) and never realized until 2010 show.
          • Enzo C.
            • January 11, 2012
            • 534
            Hi Alan, what do you mean by operation of ignition switch... I believe...... in 63 the key could be removed when the engine was running?
            Enzo Colosimo
            ENZ-Z06/67
            • Gary B.
              • January 31, 1997
              • 6992
              Enzo,
              Alan is referring to the ability to remove the key only when it is in the LOCK or ON positions.
              Gary
              • Enzo C.
                • January 11, 2012
                • 534
                Ok Gary... So as my last reply...... the key can be removed in the ON or running position?
                Enzo Colosimo
                ENZ-Z06/67
                • Gary B.
                  • January 31, 1997
                  • 6992
                  Enzo,
                  The question is, can your key be removed in positions other then ON (running) and Lock, i.e., ACC or OFF positions?
                  Gary
                  • John D.
                    • November 30, 1979
                    • 5507
                    Enzo, I only had one original key for my 63. Still had the number on the key. Sent it to Peter Lindahl aka the key guy. He sent me back a Corvair key he had in stock with the identical number on it as my 63.
                    Said for me to try it in all my locks and let him know if it was OK.
                    It was perfect so he then made me two new keys that the judges loved.
                    By the way Pete you don't charge enough for all the service you give us. Seriously. Thanks, JD
