1963 stock 250hp 4 speed carb question - NCRS Discussion Boards
  • Frank D.
    • December 27, 2007
    • 2703
    I've rebuilt my WCFB 3501S exactly to spec and it idles and pulls strong (for a mouse motor).
    If I nail it at low RPM she'll buck a bit and then take off like a shot -- no problem at higher RPMs.
    Is that just the way it is ? Accel pump has super double shot of juice when blipping the linkage, float level/drop is perfect, etc..
    I know my dual quad '61 has to be 'up' on the Duntov cam for best WOT performance. So, am I just being picky ?
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 1963 stock 250hp 4 speed carb question
    Frank,
    If I was having that trouble I would advance the timing a couple of degrees at a time and check it each time I advanced the timing. Don't advance it enough to get pinging when you push on the accelerator. If it pings just back off a couple and try that.
    JR
    • Frank D.
      • December 27, 2007
      • 2703
      Originally posted by Joe Ray (1011)
      Frank,
      JR
      Easy enough, I'll try it tomorrow... Thanks Joe...
      • Harry S.
        • July 31, 2002
        • 5344
        JR has a great suggestion. I'm running my 250 hp 63 about 11 degrees advanced.
        • Timothy B.
          • April 30, 1983
          • 5201
          Frank,
          FWIW, to much accelerator pump shot can make it feel lazy.
          • Frank D.
            • December 27, 2007
            • 2703
            Lars setup my original distributor last year for 16* initial (long story) and I ran that way for a while but backed off to about 12 in January.
            Think I'll try bumping it back up to 16* - it never pinged that high...can't hurt.
            I don't think my pump shot is excessive but I'll look at that too...not much adjustment in that arena on the WCFBs though.
            • Frank D.
              • December 27, 2007
              • 2703
              Bumping up the timing definitely helped; I'm at 16* initial (vac advance plugged); no pinging under load and no 'trailer-hitching' at cruise.
              Still have the tiniest bit of bog at WOT from cruise (none at idle). Don't know if I should live with it or try to goose the timing up another degree or two.
              • Frank D.
                • December 27, 2007
                • 2703
                Slight carb adjustments and advancing the timing worked superbly - thanks JR...
                • Stan E.
                  • April 30, 1991
                  • 383
                  My first thought was the same.
