C3 1981 Frame Stencil - NCRS Discussion Boards
  • Tom R.
    • June 30, 1993
    • 4105
    Re: C3 1981 Frame Stencil
    Originally posted by Fred Sarbello (11358)
    Tom, OK sorry but what is the AIM sheet and what is MJ shipped? Thanks, Fred
    The AIM is the assembly instruction manual for each model year. In #13 above you reference
    The corvette assembly manual lists the frame number as 14020218 which is not what is on my frame
    so where did this come from? My assumption...the AIM!
    MJ represents and refers to the Michael Johnson post above.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • Fred S.
      • April 30, 1987
      • 48
      Tom, The AIM sheet that I have shows no change orders or revisions.
      • Fred S.
        • April 30, 1987
        • 48
        Michael,
        I have one more question....when you respond to the frame suffix question, could you tell me if you still have the engine suffix code label on the rear of the passenger side valve cover....if yes, what is the format (size, colors, letter/number arrangement, etc.)....mine should be 81ZDD or some other number and arrangement of these digits. Thanks, Fred S.
        • Michael J.
          • January 27, 2009
          • 7176
          OK will do Fred, I am still out in 'Vegas watching the many NCAA basketball conference tourneys here, but should get back to home and the car on Monday.
          • Michael J.
            • January 27, 2009
            • 7176
            Finally back. The suffix is 301, and I see no stickers/label (or any evidence they were ever there) on the back passenger side valve cover on mine.
            • Tom R.
              • June 30, 1993
              • 4105
              You wrote earlier:
              I have my build sheet too, there is a job sequence # (upper left corner) which is not the VIN, below that is the sched. no. and date, which is 17 and the last 4 of the VIN and 07-30, but it was actually built August 3, and for frame it only says 144.
              In summary:
              6-13-81 - Frame assembly date
              07-30 Expected date of production (buildsheet)
              08-03 Trim tag date code
              Tom Russo
              78 Pace Car L82 M21
              00 MY/TR/Conv
              • Michael J.
                • January 27, 2009
                • 7176
                Originally posted by Tom Russo (22903)
                You wrote earlier:
                In summary:
                08-03 Trim tag date code[/COLOR]
                I think I need to amend that actual build finish date after looking a bit more closely, I think it was probably either July 31 or August 1. It was pulled off the line for a minor paint repair/touchup it appears. The trim tag body date is 5th week of July.
                • Fred S.
                  • April 30, 1987
                  • 48
                  Tom, thanks for this last info.....hope that you had a good trip to the NCAA games.... my team Villanova Wildcats plays end of week.
                  Fred S.
                  • Michael J.
                    • January 27, 2009
                    • 7176
                    #24
                    • Fred S.
                      • April 30, 1987
                      • 48
                      #25
                      So after this response I decided to continue my research in trying to verify the frame number, dash number and date. In looking back thru the literature binder that I received from the previous owner, I found the attached Report from AO Smith. It appears to have been tri folded and then rolled up and I assume was stuck in some obscure location in the vette. It shows p/n 14041144, dash #304 and a 7/21/81 date. It also indicates that there were 168 frames on this load from AO Smith to GMAD. This info corresponds closely to your data. Further I think that it was used on the assembly line by the worker to establish the stencil that was used and then it was stashed in the vette some place.....what do you think or Tom Russo if he reads this? If photo is not attached let me know....having some problems.
                      • Michael J.
                        • January 27, 2009
                        • 7176
                        #26
                        I think you are on to something here. I have never seen a document like this, but what you say makes sense.
                        • Tom R.
                          • June 30, 1993
                          • 4105
                          #27
                          This is very cool and something I have not seen before so quite a nice piece of factory documentation. As you conclude the assembly number for your frame should be the 14041144-304. So 304 becomes the lot number. How nice is that? Frame stencil not attached.
                          Remember now that the frame stencil would have been applied at A.O Smith rather than the BG plant.
                          Wait a day or two but I would really like to see a broader audience take a look at this document and get some opinions. Let's start a new discussion thread. Title it "A.O. Smith 1981 frame assembly document. Anyone see one like this before?
                          Tom Russo
                          78 Pace Car L82 M21
                          00 MY/TR/Conv
                          • Michael J.
                            • January 27, 2009
                            • 7176
                            #28
                            A new thread on this interesting topic is a good idea Tom.
                            • Tom R.
                              • June 30, 1993
                              • 4105
                              #29
                              Yeah...some of the early C3 guys would be familiar, or so I think, with this sort of documentation. Put "A.O Smith" in the title and its like flys on s__t so to speak! LOL
                              Tom Russo
                              78 Pace Car L82 M21
                              00 MY/TR/Conv
                              • Michael J.
                                • January 27, 2009
                                • 7176
                                #30
