Jasper Engine Rebuild - NCRS Discussion Boards
  • Herb P.
    • April 19, 2011
    • 37
    I am thinking about having my original '67 L-79 engine rebuilt by Jasper Engines in Indiana. Has anyone had them rebuild their motor and if so, were you satisfied with the results? Thoughts?
  • Michael H.
    • December 1, 1987
    • 733
    Re: Jasper Engine Rebuild
    Herb you should be able to find someone close by to rebuild your motor. Have you contacted any NCRS members near you for there recommendations ?
    Mike
      • 6961
      Herb, I agree with Mike, if your dealing with your original engine you will want to make sure the machinist knows about not touching the stamp pad. Once the numbers are removed the gone forever. Decking the block is a common practice for places like Jasper Engines, I have used them at my shop for replacement engines and they do a great job for everyday drivers--- But replacement of all the parts you normally think should be replaced sometimes is not. Such as lifters, oil pumps are sometimes refurbished in housing, not replaced. camshaft are sometimes reground, and the biggest issue is there measurements are to much on the give and take. And there is much more.
      • Paul O.
        • August 31, 1990
        • 1716
        Herb
        Are you using their engine restoration shop at Jasper. Had a tour through that facility several years ago. Their restoration engine shop did all the right things to save all original markings on an engine. But they had detailed instruction from the owners of those engines. That shop is totally separated from their production area. It is maned by a small and dedicated team of engine restores.
        • Herb P.
          • April 19, 2011
          • 37
          Thanks for the responses. My mechanic has been in touch with Jasper and has provided instructions on the rebuild. He has also marked the block and heads to assure we get the original ones back.
          It is hard to overlook the 3 year/100k guarantee they provide.
