C2 washer squirter washers - NCRS Discussion Boards
  • Enzo C.
    • January 12, 2012
    • 536
    Gents I would like some clarification on the size of the black washers for the squirters on the cowl. Should they be the same size as the squirter base? Is there a procedure to make this correct? I got a deduct at the last regional and would like to rectify this problem..... Thanks
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
    • 6956
    Re: C2 washer squirted washers
    Enzo, Don't quote me on this but I thought that someone here on the TDB said the rubbers washers were square cut and the small block chevy. valve seals were correctly sized. Someone please correct me if I'm wrong.
    • Enzo C.
      • January 12, 2012
      • 536
      Hi Ed, not sure if you are answering my question? I meant the windshield washer squirter washers on the cowl
      Enzo Colosimo
      ENZ-Z06/67
      • Stewart L.
        • March 1, 1980
        • 356
        The gaskets don't stick out beyond the nozzle. I just got some from LIC, they are just right.
        • Ed S.
          • August 6, 2014
          • 1388
          Paragon sells washers that are the correct size as well but.... regardless where you get them from be careful when tightening the squirter down, the rubber washer compresses easily and will protrude beyond the circumference of the squirter base if you over-tighten it ---- and it doesn't take much to do that.
          Ed
          • Alan D.
            • January 1, 2005
            • 2053
            Does anyone have a picture of an original on car? Something does not sound right here!
            It's pn 3776302, but I can not find in the limited books I have.
            • Ara G.
              • January 31, 2008
              • 1108
              Enzo,
              Just use an exacto knife and very carefully trim the excess rubber. Takes two minutes (recommendation is to do this while NOT under the influence of caffeinated beverages due to hand shake....lol). Otherwise, you can scribe the gaskets while on the car, remove and trim excess/protruding rubber and re-install. The gaskets, as posted already, should not protrude past the base of the squirter....Best to my Canadian friends....ARA
              • Enzo C.
                • January 12, 2012
                • 536
                Hi Ara, have you tried this process ? One has to be very steady and you don't have a second chance... Apparently there is a note in the new 65 judging manual to check if washers have been trimmed to take a deduct ? I would rather buy correct washers and not take any chances to scratch my wonderful paint job...
                Enzo Colosimo
                ENZ-Z06/67
                • Jimmy G.
                  • November 1, 1979
                  • 977
                  As was earlier posted small block valve stem seal are almost perfect in size and are CHEAP.
                  • Enzo C.
                    • January 12, 2012
                    • 536
                    My apologies Don, I did not mean to make a false statement... I took a friends comment and I guess I misunderstood ... I will simply buy the washers fro LIC and go from there... Thanks for your comments
                    Enzo Colosimo
                    ENZ-Z06/67
                    • Stewart L.
                      • March 1, 1980
                      • 356
                      The sharp edges described in the new manual are edges on reproduction nozzles.
                      • Enzo C.
                        • January 12, 2012
                        • 536
                        Thanks Stewart I guess that's what my friend meant...
                        Enzo Colosimo
                        ENZ-Z06/67
                        • Alan D.
                          • January 1, 2005
                          • 2053
                          So how does that fit into the "CDCIF" process? A special consideration for "65" only? It's only a 3/3 item, so to take 1 on original side seems like double dipping plus! So if one has a repo washer nozzle the C &/or D could be at risk also. Again, does anyone have pictures of originals?
                          • Mike E.
                            • February 28, 1975
                            • 5141
                            Here are some pics of a 30k-mile 67. Never removed. The best I could do for photos.
                            Washer nozzles and gaskets (1).jpgWasher nozzles and gaskets (2).jpgWasher nozzles and gaskets (3).jpgWasher nozzles and gaskets (4).jpg
                            • Stewart L.
                              • March 1, 1980
                              • 356
                              Washer Nozzles- How are these? Check out this thread for 2010, it has some related info.
