1963 Ashtray - Above VIN 17500 - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5334
    Quick Survey.
    If you believe you have the original ashtray to your 63 and you VIN is above 17500 please let me know if you have the single tang on the side (1" x 3/4") or the U shaped tang. This is the metal clip that holds the ashtray in place when installed.
    I'm trying to determine the approximate VIN when the ashtray changed, just another 63 anomaly.
    Thank You
    My 13356 car has the 1" x 3/4" tang design
    My 20018 car has the U shaped tang design
  • Keith W.
    • June 30, 1998
    • 375
    Re: 1963 Ashtray - Above VIN 17500
    Early 63 u shape tang clip
    • Edward J.
      • September 15, 2008
      • 6950
      Keith, My vin(10674) is a couple hundred from yours and I have a solid tang.
      • Keith W.
        • June 30, 1998
        • 375
        Ed mines also a coupe - correct colour is silver blue
        • Edward J.
          • 6950
          Harry, I noted that in the 63 JM there's a service bulletin pertaining to the 63 Ash tray dated late April. so maybe there was a change made sometime after this, I also noted that my 63 ash tray has a modification as per bulletin. According to bulletin they filed one edge of for easy removal.
          • Scott P.
            • April 30, 1992
            • 178
            Harry, VIN 19294 U shaped. Scott
            • Guest
              Harry - don't have my #19367 Z06 anymore, but the original ash tray was a "U-shape" tang
              • Richard P.
                • September 29, 2011
                • 96
                Hi Harry, for your search........my '63 #20655 has the U shaped tang. I'm anxiously awaiting publication of your book of "Meditations on the '63 Corvette". I'm sure it will be more than one volume.
                • Harry S.
                  • July 31, 2002
                  • 5334
                  A Book? must be another Harry. Thanks for the ashtray information.
                  • Edward J.
                    • 6950
                    Harry, might not be a bad Idea, so many changes in the 63 corvette it almost warrants a book.
                    • Perry M.
                      • January 1, 1977
                      • 325
                      Harry, my '63 SWC has the ''U'' shaped tang. It is VIN #17622
                      • Sydney G.
                        • February 1, 1994
                        • 444
                        Hi Harry,
                        I just checked for you and my coupe #15,240 also has the "U" shaped tang.
                        Syd
                        • Harry S.
                          • July 31, 2002
                          • 5334
                          All, I'm getting some interesting findings,
                          Anyone, any VIN, and if you believe it's the original ashtray please let me know what the style you have is.
                          • Jon R.
                            • February 8, 2010
                            • 163
                            Harry,
                            15192 & 19749 both have the "U" shaped tang.
                            Jon
                            • Joseph S.
                              National Judging Chairman
                              • March 1, 1985
                              • 894
                              This is a great thread. I'm not trying to be a "Buzz Kill" here, just trying to help Harry with his research. I have car 9301, original interior, dismantled in 1975 and it had the solid 3/4" tang. Can all of you comment on the chain of custody of your car and whether it still has the original interior. There may be a chance to find out when and if the solid tang ashtray changed to the U shaped tang. Most of you that have commented have cars above 15,000. Perhaps Harry should have asked for comments from people with earlier cars. I see most of you have the U shaped tang.
