Looking for tips & advice from those who have replaced their original (4-qt capacity) oil pan with GM replacement #360866 or one it's common repro equivalent.  For example:
Must the oil pump pickup be changed?
Does the OEM dipstick/tube assy' retain measurement accuracy?
Recommended gasket set?
Do these pans employ the post-'75 larger radius for front seal?
Does the 'side' position of the drain plug cause any concern during oil changes ... like slobbering on p/s cylinder, linkage
Thanks in advance.
Jeff
Thanks in advance.
Jeff
