1970 Tank sheet - NCRS Discussion Boards
1970 Tank sheet
  • Ralph S.
    • February 1, 1985
    • 935
    1970 Tank sheet
    DSC00775.jpgHave you ever seen one with the numbers typed in the right hand column
  • Dave S.
    • August 31, 1992
    • 2930
    Re: 1970 Tank sheet
    Originally posted by Ralph Spears (8296)
    [ATTACH=CONFIG]68690[/ATTACH]Have you ever seen one with the numbers typed in the right hand column
    My 70 Ls-5 ##11756 had one just like yours. Not sure where it came from but was in the fiber tray when I bought the car. As I recall there were 6 or 7 copies of the sheet and this was one of the bottom copies. Others will have better info. Nice find for the right car. It must be a Luby Chevrolet car.
    • Stephen L.
      • May 31, 1984
      • 3162
      Re: 1970 Tank sheet
      The typical "tank sticker" was generated when the order for the car was received/processed. This is a page that had the original information, and was completed after the car was built. As you can see this sheet has "typed in" information with the various numbers unique to the items installed such as the key codes, dates etc. Additionally it carries the serial number of the completed vehicle. This document is better than a "tank sticker" for accurate documentation of a particular vehicle.
      Good find!!!!!!!!!!!!!!!!
      • Ralph S.
        • February 1, 1985
        • 935
        Re: 1970 Tank sheet
        Yes it is a Luby/ Boston car.
        • Jimmy P.
          • June 24, 2014
          • 1696
          Re: 1970 Tank sheet
          Hi Ralph,
          Stephen is correct. Your photo is not an actual tank sheet. It is the dealer's copy. Yes it was common for these items to be typed in that area on this particular form. It has all the unique items listed above, these were essential for both the plant and the dealer. All the handwritten information from the various line inspectors and broadcast copies were typed manually by a clerk on the form you mention in the lines on the right in the"Corvette Order" This copy #7 was then placed in the car's glove box for the dealer thru 67. These forms were also found in various other places in the car starting with 1968. The owners found them between the speedometer/ tach, tucked up under the seats., under the carpet etc.
          BTW, Stephen: I was just looking at Tom Russo's "Corvette Buildsheet Book" and noticed your sample copies of the Corvette Dealer Order Form, Corvette Order #7, and the original Tank Sticker" Great Stuff, and very interesting....
          Hope this helps explain some things, Ralph!
          Jimmy
          Last edited by Jimmy P.; February 13, 2016, 08:18 PM. Reason: Added more information!
          Jimmy
          1973 Convertible
          L48,M20,N40
          Mille Miglia Red/Oxblood
          • Jim T.
            • March 1, 1993
            • 5351
            Re: 1970 Tank sheet
            Originally posted by Jimmy Patitucci (60161)
            Hi Ralph,
            Stephen is correct. Your photo is not an actual tank sheet. It is the dealer's copy. Yes it was common for these items to be typed in that area on this particular form. It has all the unique items listed above, these were essential for both the plant and the dealer. All the handwritten information from the various line inspectors and broadcast copies were typed manually by a clerk on the form you mention in the lines on the right in the"Corvette Order" This copy #7 was then placed in the car's glove box for the dealer.
            Jimmy
            My 1970's was not in the glove box, was removed from above the speedometer. My 1968's was located behind the radio.
            • Jimmy P.
              • June 24, 2014
              • 1696
              Re: 1970 Tank sheet
              You're right Jim,
              They were also found under the carpeting, tucked up in the seats, and even in the suspension. I did add this information to my previous reply.
              Thank you!
              Jimmy
              1973 Convertible
              L48,M20,N40
