Tried on another site but I need help here.
My 64 has its original engine and intake, and I have found a correct Carter Carb for it. I picked up the air cleaner used, was supposed to be for a 64. The crankcase vent tube is from LI Corvette. I have since noticed a different tube available from Paragon. The problem is that the tube from the block hits the tube from the air cleaner and does not allow the air cleaner to sit down on the carb. I would like to confirm the air cleaner is correct, and the carb is spaced properly before I go back to LIC and ask for a return. Any other ideas?
