63 Ground Strap Star Washer - NCRS Discussion Boards
  • Alan D.
    • January 1, 2005
    • 2054
    Re: 63 Ground Strap Star Washer
    Similar mistakes, L Washer for tooth washer, can be found through the AIM's - so common error, stick with part number
    • Michael G.
      • November 12, 2008
      • 2158
      Harry, Leif's note says yes on the '67's.
      (edit, ooops, yes '67, it says L. Washer but IIRC it is actually a toothed washer.......Yes the pic shows toothed and the part# is a External Toothed 3/8" diameterlock washer.)
      But just wondering. The 448645 "SCREW" as called out in the AIM.......I know it doesn't say "SCREW ASSEMBLY", which would typically denote a screw and integrated washer, but I'm wondering if it actually is a "assembly" and the AIM is in error in it's description.
      Just thinking.....
      Rich
      p.s. one other tidbit....the 2981858 "Strap ASM - GROUND" is a Assembly. Could it have had a LW integrated to it?
      p.p.s. I'm reaching, i know....
      Reaching pretty far.... On grounding attachments, such as the one in question here, external toothed lock washers were loose assembled under the ground strap, (to scrape the paint or other crud off of components), not as an assembly with the screw. The screw head was already making great grounding contact with the strap, a washer would have done nothing.
      Mike
      1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
      1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
      • Harry S.
        • July 31, 2002
        • 5346
        #18
        After some consultation I've come to the conclusion that the 63, 64 and 65 did not have the star washer. I tend to agree that the 67 called for a lock washer but after looking at the part it's actually a star washer. No conclusion on the 66 yet.
        I do not plan to install one.
