63 Ground Strap Star Washer - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5346
    Well, I started going through my judging sheets to get ready for this years National. Just fixing the simple things.
    I lost a point because I was missing the star washer on the ground strap that attaches to the linkage. There is no star washer called out in the 63 AIM Section U65 that I can see. Can any of you 64 to 67 owners look at your AIMs and see if one is called out.
    Maybe I can get a point by doing nothing???
  • Hank D.
    • January 1, 1999
    • 138
    Re: 63 Ground Strap Star Washer
    Hi Harry -
    I see lock washers in the 64 AIM only for the chassis and engine ground straps, but NOT for the accelerator linkage.
    Hank
    • Alan D.
      • January 1, 2005
      • 2054
      The 64 AIM, U69 s5.00, shows no L Washer at the accel lever. In fact on that page are four diagrams, three of them show the use of item #1, L Washer pn 121753. Neither does the 63 Shop Manual, 13-11 show a L Washer. Think this is just a small error that never gets cured. As I recall the ground straps only got a Washer when the surface was painted - to brake through the paint to get a good ground.
      What does the JG expect, may be easier to add than fight, (look who's talking)
      • David Z.
        • April 1, 2002
        • 183
        My '65 AIM only shows a screw (448645) in the drawing at the lower right of the page.
        Dave Z
        Dave Zuberer
        • Harry S.
          • July 31, 2002
          • 5346
          The 63 JG calls for one, external star.
          • Michael G.
            • November 12, 2008
            • 2158
            Well Harry, I think this is a trick question...the sixth edition seems to be covering all the bases, i.e. it calls for a washer, but includes an AIM drawing that doesn't show one...
            Before settling on no washer for Nationals, I found an original car that was lacking this heavenly body, so I went that way. (see pic) I didn't get a deduct, but it probably could have gone either way. Good luck...
            Mike
            1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
            1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
              • 6958
              Harry at our last regional seasoned judges found I was missing the star washer@ accel. lever, so I installed one, the star washer was discussed here a few times on 63 and everyone says NO! but the JM says yes, to make them happy its there now. I kind of feel that with it there you may win, as that's what is in the JM.
              • Timothy B.
                • April 30, 1983
                • 5202
                I can tell you my November 63 car did not have any star washer. I believe I was the first to remove the bolt and the eye lid for the broken missing ground cable was still there.
                • Don H.
                  Moderator
                  • June 16, 2009
                  • 2282
                  Harry
                  you can get dinged with it, and get dinged without it. I would make it the way you know is right and let the chips fall. No L washer.
                  Like Tim above, I was the first to remove broken ground strap remnant from my Jan 64 L84. No L washer, and no sign of one ever having been there.
                  • Leif A.
                    • August 31, 1997
                    • 3654
                    Harry,
                    You asked for '64-'67 owners to chime in so here's what I read. In the '67 AIM, U69, A3 it calls for L. Washer #138489. The 5th edition TIM&JG on page 123, calls for an external tooth washer between the ground strap and accelerator lever.
                    Leif
                    • Harry S.
                      • July 31, 2002
                      • 5346
                      Interesting, sound like none of the 63 to 67 AIMs call for a star washer.
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11365
                        Originally posted by Leif Anderson (29632)
                        Harry,
                        Harry, Leif's note says yes on the '67's.
                        (edit, ooops, yes '67, it says L. Washer but IIRC it is actually a toothed washer.......Yes the pic shows toothed and the part# is a External Toothed 3/8" diameterlock washer.)
                        But just wondering. The 448645 "SCREW" as called out in the AIM.......I know it doesn't say "SCREW ASSEMBLY", which would typically denote a screw and integrated washer, but I'm wondering if it actually is a "assembly" and the AIM is in error in it's description.
                        Just thinking.....
                        Rich
                        p.s. one other tidbit....the 2981858 "Strap ASM - GROUND" is a Assembly. Could it have had a LW integrated to it?
                        p.p.s. I'm reaching, i know....
                        • Harry S.
                          • July 31, 2002
                          • 5346
                          Rich, I thought Leif's note said yes to lock washer not star washer?
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11365
                            Harry, I just edited my reply above. It's the ext toothed type....Pics from my 29-59 P&A book. 138489
                            • Leif A.
                              • August 31, 1997
                              • 3654
                              Harry,
                              The AIM does identify the washer as a "L. Washer" but looking at Rich's part number picture it appears the part number listed in the AIM as a L. Washer is actually a external tooth washer...confusing, huh??
                              Leif
