Intake Manifold Install in Cold Weather - NCRS Discussion Boards
  • Thomas B.
    • November 24, 2015
    • 26
    Hello:
    Is there any concern with installing a cast iron intake manifold on my 1970 350 engine when it is cold (25 degrees) in my garage?
    Thanks in advance for your response
  • Tom L.
    • October 17, 2006
    • 1439
    Re: Intake Manifold Install in Cold Weather
    Yes, you will get very cold. Consider a heater.
    To be serious, I doubt it. Others will chime in.
      • 43220
      Originally posted by Thomas Borruso (61803)
      Hello:
      Thomas------
      No problem. However, if you use RTV silicone sealer in place of the rubber end seals, as I highly recommend, it will take longer for the RTV to cure.
      • Jerry W.
        • January 27, 2009
        • 588
        The coefficient of cold Cast Iron to Fingers is about the same as using an Out-House in January....What Joe said.
