64 Hood release T handle - NCRS Discussion Boards
  • Greg H.
    • June 2, 2008
    • 254
    As I am installing my hood latches after the engine bay has been refinished along with the body, I make it all the way to the T handle under the dash board. It's an ugly mess, so I have removed all the old chipped paint. Once I paint it with Semi-gloss black, along with the bracket, how do I replace the white lettering that reads "HOOD RELEASE"? Smear white paint then wipe it? Any tips?
    Greg
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 64 Hood release T handle
    Exactly. You could use a white marker too like a metal marker. Let the black dry well first tho.
    • Frank D.
      • December 27, 2007
      • 2703
      Get yourself a lacquer stick --- heck get two -- one for the parking brake handle.
      They work a LOT better than trying to brush white paint on, clean it off, then clean too much off, repaint, etc..
      • Ed S.
        • August 6, 2014
        • 1388
        Greg,
        I stripped and repainted the numbers and lines of my 4 speed shift pattern plate. While the hood release handle is plastic vs aluminum, I would suspect that the technique I used would work as well. I sprayed the plate black and waited just a bit - about 45 seconds - enough for the paint in the depressions to hold a bit. Then I took a new plastic food scraper and just pulled it over the plate. It effectively squeegeed the paint off the high surfaces and left paint neatly in the depressions. I still had just small traces of black paint on a few high spots - I got these off by lightly rubbing the plate against a piece of cotton cloth that was damp with acetone. Actually, I had the cloth spread tightly on a table and place the plate face down on it and moved the plate back and forth twice with very light pressure. Came out perfect.
        Ed
