Vintage Air in 63 headed for judging - NCRS Discussion Boards
  • Frank D.
    • December 27, 2007
    • 2703
    I asked about point deductions in the past for this mod and got some great answers. What I didn't see was anything about points vis a vis the radiator fan and clutch. I am running a Hayden 2747 heavy duty fan clutch and an 18-1/4" 7 blade fan (basically a later year Impala fan). The cooling is phenomenal (I hate those electric fans). So I'm wondering what the 'hit' is on those items. Point is, I have the original fan and fan clutch but I'm reluctant to swap them on unless there is some real benefit point-wise.
  • Harry S.
    • July 31, 2002
    • 5295
    Re: Vintage Air in 63 headed for judging
    Frank, if the part in question is not a corvette part you should expect a 100% deduction on originality and a 100% deduction on condition. You could debate the fan but I think that's 100% also.
    • Joe R.
      • July 31, 1976
      • 4550
      Frank,
      A big block sold at Barret-Jackson with an LS-7 454 Vintage Air, Aluminum Radiator and clutch fan for 190K. It was the All-American 1966 Corvette as it had a part from all 50 states.
      Good luck! Its your Corvette and you can do anything you want with your Corvette. Just remember you are playing by their rules so if you wanna play you can't be a cry baby!
      JR
      • Frank D.
        • December 27, 2007
        • 2703
        Not crying - just working on my strategy.
        Do I take off certain parts that will make the car less streetable to garner some points or stick with what I have and eat the deduct ?
        I'm sure plenty have been through the same drill...
        • Harry S.
          • July 31, 2002
          • 5295
          Frank, we assume your getting you car ready for the Florida Regional for Flight Judging. Depending on how your car is getting there is a consideration. The outside temperature is another. If you have pre-judged your car and your close to 94% is another. Saying that, if your close and don't need the A/C, I'd suggest you put the original parts back on the car.
          If your looking to PV the car then you need a 97% Top Flight.
          • Michael J.
            • January 27, 2009
            • 7122
            I had a '66 L79 coupe with Vintage Air (worked great too), side exhaust (an AO Smith body), Western Wheel knockoffs and radial, gold line tires, also green leather interior (that color only came in vinyl from the factory), but you know what? I loved the look, feel and drivability of the car so much I didn't change anything for the regional. It came in Second Flight, but so what, enjoy!
            • Frank D.
              • December 27, 2007
              • 2703
              I thought you couldn't even enter a PV with aftermarket air conditioning - did I read that NCRS PV guide wrong ??
              BTW - is this an original fan clutch for 63 base motor...obviously an Eaton with a Dec, 18th, 62 stamp, no "CJ" stamp
              and no patent numbers that I see. It had leaked slightly in storage - no idea if its still good or not.
              The contours on the face are different than the JG picture is what raised the question...
              • Joe R.
                • July 31, 1976
                • 4550
                Frank,
                I know your not crying now but when the judging is over was what I was talking about. Your one of the few that wants your Corvette streetable and enjoy the wind in your hair! I respect that and that's why I am building a Corvette Resto-Rod. To enjoy it!
                Take your Corvette to judging and show it off and build it like it's your baby!!!
                JR
                • Frank D.
                  • December 27, 2007
                  • 2703
                  Its all good. I made the decision early on to add Vintage Air regardless of the judging consequences; even though some purist friends advised against it. Some said to remove it. That ain't happening and I'm just trying to minimize point loss for simple things now. The car "is what it is"...
                  Its interesting cuz now I'm digging around in my Tupperware bins finding original parts I forgot (or never knew) I had !!
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    Frank,
                    The Fan and Fan Clutch are each worth 5 originality points and 4 condition points. (found on the chassis judging sheets) If they differ significantly from what should be on your car, then the the judges can deduct all 18 points for these items.
                    If they can achieve at least 10% of the originality points, then they will earn condition points on there own merit.
                    As you "discover" original parts in your stash, you can evaluate the point value by looking at the copies of the judging score sheets that will be used on your car at this link.
                    https://www.ncrs.org/services/judging-score-sheets.php
                    good luck,
                    tc
                    • Loren L.
                      • April 30, 1976
                      • 4104
                      Frank, if you have a 1962 stamped fan clutch, take it off and send it to either the Smithsonian or the Heritage Center, because it's the only one.
                      • Gene M.
                        • April 1, 1985
                        • 4232
                        Frank,
                        I have VA on my '65 so I know all the deviations from original. The basic operations of VA is going to take you out of contention. The fan and clutch are the least of you problems points wise. There are so many other changes associated with the VA that flight judging and pv should be of no big surprise as to the points that will be lost. Enjoy the air and drive the car........!
                          • 6942
                          Frank, good luck with flight judging, hope you achieve a T/F. wish I was going to Fla. have not made it yet but will hope for next year as retirement is close.
                          • Chuck G.
                            • May 31, 1982
                            • 2034
                            Originally posted by Gene Manno (8571)
                            Frank,
                            I have a friend here in Florida who has had his 67 SB coupe judged several times... at at least 2 Chapter meets, and at 1 Regional... in Old Town, and has gotten Top Flight awards at all events.
                            Chuck
                            • Frank D.
                              • December 27, 2007
                              • 2703
                              I'm at a. car cruise right now with two NCRS judges and they did an impromptu pre-judging. I have a lot of small things to tackle still. Mostly bolts and gaskets. I'd be happy with any flight at this point.
