The fuel pump for ALL 1963's, all HP ratings is simply referred to as "#4657" in the NCRS judging manual.
I'm looking for one for my car - and see several that have suffixes of JF, AF, CF, LD so far.
Are these suffixes date codes? Did the non-correct service parts have the suffixes?
Also - the manual states the cast bottom should have 4 screws holding it on - all the pumps I've seen have only 2.
Would these be service parts?
Here is a pic of a "rebuilt original" by one of the larger vendors that is listed as "correct" coded 4657JF. This vendor does differentiate from "replacement" and "correct" part numbers and show pictures of the AC tops being different, so they appear to understand the difference between "service" and original parts, FWIW:
Here is a pic of a used "original" by a large Corvette restorer/dealer coded 4657LD:
						 #4657 Fuel Pump Question
