1964 Ignition Switch - NCRS Discussion Boards
  • James C.
    • July 4, 2012
    • 81
    I have a 64 w/the ignition switch w/two holes for removal. The closer to twelve o'clock disengaged and removed the switch. When the switch was removed I couldn't locate any numbers on the barrel. I assume this is a replacement ignition switch or from a later year vette/chevy??
    Re: 1964 Ignition Switch
    James -
    Yes, the presence of two holes indicates that the lock cylinder/tumbler is a Service replacement; the original only had one hole.
    • Harry S.
      • July 31, 2002
      • 5349
      James, you can replace the two hole bezel with a one hole bezel. It just pops off, use a small bit of silicone when you put the one hole bezel on.
      • Dan H.
        • July 31, 1977
        • 1372
        James, also check for proper function of the switch by testing that it only comes out in the 'on' and 'lock' positions. Many have worn tumblers and will also come out in the 'lock' position, which it shouldn't do. New tumblers usually fixes this, then you can PV your car in style!
        Dan
        1964 Red FI Coupe, DUNTOV '09
        • Dan H.
          • July 31, 1977
          • 1372
          OOPS, the key shouldn't come out in the 'off' position or 'acc' position.
          Dan
          • Robert B.
            • March 1, 1992
            • 265
            my 63 has 2 holes also. where do I get the correct one.
            • Harry S.
              • July 31, 2002
              • 5349
              I got mine from Pat of Pat's Locks in MD. He sold the business and it's now called PYCL. It's in Hatfield, PA.
              800-542-7278
              • Gary B.
                • February 1, 1997
                • 7098
                Harry,
                I knew for the past five years or so that Pat Kraus was looking to retire and sell the business, but I wasn't aware that he had taken that step. What do you know about the new owner?
                Gary
                • Gary B.
                  • February 1, 1997
                  • 7098
                  800-542-7278
                  Harry,
                  I found the website for PYCL Classic Locks. It says "wholesale only". That's a real shame.
                  Gary
                  • Harry S.
                    • July 31, 2002
                    • 5349
                    Originally posted by Gary Beaupre (28818)
                    Harry,
                    Gary
                    I met him at Carlisle a few years back, he seemed ok to me. I did not do any business with him.
                    Pete Lindahl may have the parts available.
                    • Gary B.
                      • February 1, 1997
                      • 7098
                      Harry,
                      Pat had a few lock parts that he had custom-made that no one else has.
                      Gary
