C2 Reproduction Window Regulators - NCRS Discussion Boards
  • Stewart L.
    • March 1, 1980
    • 356
    Has anyone used these? Any problems? Its for a manual window on a roadster. I just need a left but you have to buy both it appears.
  • Dan H.
    • July 31, 1977
    • 1372
    Re: C2 Reproduction Window Regulators
    Hi Stewart, I had a LH one in my 64 Coupe, it loosened up with a lot of play after a year. The peened over retaining studs had loosened up, permitting too much slop. I drilled them out and tapped in 1/4 20 bolts, worked fine. I eventually procured an NOS one, same problem with loosening of the peened studs. Installed bolts in it too. Be prepared to test and correct anything you buy for best results.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Guest
      I had to replace the left regulator on my 1966 also. I bought the pair from Long Island Corvette supply. It was replaced 2 years ago and has been working fine
      Mark
