Sticking choke - NCRS Discussion Boards
Sticking choke
  • Robert B.
    Infrequent User
    • January 1, 2000
    • 4
    Sticking choke
    62 Fi (7360) choke valve sticking in open position. Possible solutions
  • Jim L.
    • September 30, 1979
    • 1808
    Re: Sticking choke
    This is a common problem with '62 - '65 FI units.
    The choke shaft sticks usually because the venturi cone (through which the shaft passes) will, over time, begin to sag. Once the cone begins to sag, the multiple holes through which the choke shaft must pass no longer line up.
    Different rebuilders have different solutions for this. With care and controlled force, the venturi cone can be persuaded to return to its original position. I prefer to re-bore the holes so they all align again. I also polish the choke shaft with 1500 grit paper.
    Of course these operations are performed with the whole choke assembly completely disassembled. When re-installing the choke plate, it's important to ensure it is installed straight and doesn't catch on the interior walls of the venturi cone.
    Jim
    • Robert B.
      Infrequent User
      • January 1, 2000
      • 4
      Re: Sticking choke
      I am located in South Carolina. What services do you provide and where are you located?
      • Jim L.
        • 1808
        Re: Sticking choke
        So as to not clog the forum with anything which sounds even remotely commercial, I've replied to you via PM.
        Jim
