66 Small Block Exhaust Clamps - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2587
    The 66 and 67 TIM&JG describe and show pictures of the guillotine style clamps. The AIMs has part numbers U-Bolt=3853726 and Clamp=2385666 for the forward clamp and part numbers U-Bolt=3791371 and Clamp=3791357 for the rear/exhaust tip clamp. The TIM&JG simply states that the exhaust tip clamp is "...the same guillotine style clamp as described above".
    For the manual transmission cars, these were 2 1/2" clamps.
    Since there are two different part numbers in the AIMs, I assume there were two different Clamps. What was the differences?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Gary B.
    • February 1, 1997
    • 7064
    Re: 66 Small Block Exhaust Clamps
    Don,
    The clamp for the exhaust tips is 2.0". As you said, the clamps at the connection between the front and mid-pipes for manuals transmission '66 ad '67 is 2.5". The 2.5" clamps uses flanged nuts (still available from GM # 1359887) with no lock washer; the exhaust tip clamps uses regular nuts and a lock washer.
    Gary
    • Donald H.
      • November 2, 2009
      • 2587
      Thanks Gary. I should have just measure my tips!
      I wasn't sure since my car had an under car baffled exhaust system when I purchased it.
      I'm going to order a set of the clamps that Greg Thompson is advertising the the Driveline.
      Don
      Don Harris
      • Gene M.
        • April 1, 1985
        • 4233
        Understand on 65 and back the base engine used 2" pipes all the way back on both 3&4 speeds. As did the SB automatic tranny cars.
