grease for electric window motor on my 57 vette - NCRS Discussion Boards
  • Roy A.
    • January 20, 2015
    • 17
    I would like to know the proper grease to use on my electric window motor's gear wheel
  • Mike M.
    • May 31, 1974
    • 8382
    Re: grease for electric window motor on my 57 vette
    i use white lithium grease. i use it also on the nylon rollers and the tracks they run in. mike
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      I concur with Doctor Mike.
      • Steven B.
        • June 30, 1982
        • 3989
        That is what I have used on my '57 and all my cars for decades. Steve
        • Ed S.
          • August 6, 2014
          • 1377
          Lithium grease is the way to go but.... it comes in several forms, tubes, hard cardboard canisters and spray cans. If you can get to the parts that need to be lubed go with a manual application - a dab squeezed from a tube or scooped up from the canister. The problem with spray cans, as I have observed, is that it appears to be diluted and not very thick or pasty, probably so it will vacate the pressure can and, the pressure causes it to splash all over the place. Just my experience.
          Ed
