1965 Brake Caliper Restoration images - NCRS Discussion Boards
    • October 17, 2013
    • 69
    looking for a couple of photos of restored 1965 brake caliper's specifically the machined areas. Lost a few points in Denver and trying to correct the issue. Thanks in advance.
  • Gary J.
    • April 1, 1980
    • 1241
    Re: 1965 Brake Caliper Resotration images
    The machine areas are where brake hoses go into the calipers
      • October 17, 2013
      • 69
      Thanks Gary
        • 11643
        This may help.
        Photos of some NOS caliper halves. You can see what was painted and what was machined.
        Photo 3 shows the areas that the judges look for on the top of the caliper.
        • Gary B.
          • February 1, 1997
          • 7020
          This may help.
          Patrick,
          I have this photo of some calipers that were being sold on e-bay by someone who I thought knew what was correct. But the ones in my photo are missing some areas that you show as unpainted. Do you agree that the ones in the photo I'm positing have black paint where it shouldn't be? And it looks like the ones in my photo have white paint on the upper surfaces that you show as bare. Can you comment?
          Gary
          • Russ S.
            • April 30, 1982
            • 2162
            Gary, They do have black paint on the inside between the piston where they shouldn't, but that area can't be seen when installed.
              • October 17, 2013
              • 69
              Thanks for the images Patrick. The car is from Flint (Howard Hoover did the pre buy inspection). Miss my conversations with him.
                • 11643
                Gary,
                Looks like they tried to fake the unpainted areas by painting them white.
                Some try cast blast for the effect, some paint with matte clear as well.
                Raw metal will, of course, rust.
                Patrick
                  • October 17, 2013
                  • 69
                  • Gary B.
                    • February 1, 1997
                    • 7020
                    Gary,
                    Patrick
                    Patrick,
                    Is this what should be left natural, as-machined?
                    Gary
                      • 11643
                      Originally posted by Gary Beaupre (28818)
                      Patrick,
                      Gary
                      [ATTACH=CONFIG]66058[/ATTACH]
                      Yes, plus the areas around the bleeder screws.
                      • Gary B.
                        • February 1, 1997
                        • 7020
                        Thanks Patrick.
                        Gary
                        • Paul C.
                          • November 12, 2007
                          • 511
                          Do you paint the small nut on the opposite end of the bleeder? How about the bolts that hold the two halves together>
                          Best way to make sure the paint will stick. Used a wire wheel followed by brake cleaner, and then degreasurer detergent.
