Mis-alignment of belts on a 1959, 283 - NCRS Discussion Boards
  • David B.
    Infrequent User
    • January 3, 2011
    • 8
    As I was pre-assembling the engine, (283) on the engine stand, I noticed that the fan blade/water pump pulley and the crankshaft pulley do not line up. The crankshaft pulley is about a quarter of an inch farther in towards the block than the water pump pulley. What would you recommend, pull the harmonic balancer out or add some shims between the crankshaft pulley and the harmonic balancer to line up the lower pulley with the water pump pulley?
    Any ideas?
  • Jim D.
    • 2884
    Re: Mis-alignment of belts on a 1959, 283
    Did you use the spacer that goes on the crank before the balancer? It makes up for the added thickness of the engine mount between the water pump and block.
    • David B.
      Infrequent User
      • January 3, 2011
      • 8
      No, didn't know there was a spacer back there. Thank you so very much. I'll go on the internet and see what I can find. This car had a 327 in it when I purchased it.
        • 43219
        David-------
        This is what you need:
        https://www.paragoncorvette.com/p-35...er-spacer.aspx
        • David B.
          Infrequent User
          • January 3, 2011
          • 8
          Got it, thank you.
          • Thomas H.
            • August 31, 2005
            • 1058
            Lots of good info from Rich here:
            https://www.forums.ncrs.org/showthre...s-amp-Brackets
            Tom
            2007 Z06, Lemans Blue
            • David B.
              Infrequent User
              • January 3, 2011
              • 8
              Got it, printed it out and am in the process of reviewing what I need to do correct everything. Thank you very much.
