I'm confused. In rebuilding the front end on my '59, the upper, inner "A" arm shaft has no where for the grease to go to lube anything. There is a dimple in the shaft, but no hole. The caps (nuts) with the zerk fittings are closed off by the threads engaging the inner shaft threads. So, when you put grease into the cap, it creates a hydraulic lock and serves no purpose. Am I missing something? Did I purchase the wrong kit?
Does the "A" arm pivot (go up or down) on the nuts or do the nuts pivot on the inner "A" arm shaft?
Any advice you could give me would be very much appreciated.
