1965 hardtop side bolt retainer - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    I am putting my 65 together and found the new hardtop side retainers are much thicker than the originals . I have two sets of originals one set from a 63 and one set from my 65 . I dont know which ones came from the 65 ? The difference on the originals is the hole is chamfered on one set and not on the other . besides that they are the same .The originals are also magnetic stainless .
    On the new set the head is almost twice as thick as the original and has the chamfer and is not magnetic . Both will work fine but I noticed when putting the hard top on the 63 ( it has the new ones) the top needs to be squeezed together to fit inside the retainers .
    I dont know if this will be covered in the new 65 manual but it can be detected with the hardtop on or off . If anyone has there originals on a 65 let me know if they have a chamfer . Thanks Bill.DSC_1876.jpgDSC_1874.jpgDSC_1872.jpgDSC_1871.jpg
    • 43247
    Re: 1965 hardtop side bolt retainer
    I dont know if this will be covered in the new 65 manual but it can be detected with the hardtop on or off . If anyone has there originals on a 65 let me know if they have a chamfer . Thanks Bill.[ATTACH=CONFIG]65392[/ATTACH][ATTACH=CONFIG]65393[/ATTACH][ATTACH=CONFIG]65394[/ATTACH][ATTACH=CONFIG]65395[/ATTACH]
    Bill-----
    Only one special nut was used from 1963 to 1975 for Corvettes with hardtops. That was GM #3727928. It may be that the configuration of that part was revised over the years. The original nuts on my 1969 have no chamfer.
    • Bill W.
      • March 1, 1980
      • 2000
      Not much response . Did anyone get a chance to check their hard top nuts ?
      • Alan D.
        • January 1, 2005
        • 2046
        Think Joe solved the issue however here is an original 1964 one; Sorry for poor photo however you should see the chamfer on it.
        Neither of those parts seem to be magnetic stainless.
        • John C.
          • January 1, 2005
          • 616
          Bill
          I checked my 68 and 69. All have the thin head. One nut has a chamfer, although smaller than the one shown in your and Allen's picture, and the other 3 do not. All are magnetic.
          John
