1964 300HP intake manifold detailing - NCRS Discussion Boards
  • Greg H.
    • June 2, 2008
    • 254
    Hi all,
    I have a few wire and tubing clips not exactly sure where they are mounted on the intake manifold. Two are wire harness clips, the other is the tubing clip which sits next to the carb. I want to be sure I get all these in the right location. Can anyone post a picture of the top of the engine without the air cleaner in place as a reference?
    Greg
    • 6950
    Re: 1964 300HP intake manifold detailing
    Greg, The wiring clips generally mount to the pass. upper valve cover bolts, the vacuum tubing clip mounts to the center /rear intake bolt on pass. side.
    • Bob R.
      • June 30, 2002
      • 1595
      On a 300 hp engine the two clips should be a part of the drivers side valve cover and the wire runs to the temperature sender. Which is under the thermostat housing.
      • Greg H.
        • June 2, 2008
        • 254
        Well guys, I do have the clips attached to my driver side valve cover. The clips I am referring to are mounted onto a bolt somewhere, maybe they do not belong on the intake manifold at all. They are about 2 inches long with about a 3/4 in. loop to hold the bundle or maybe it is for tubing. Not sure if they were even in the right place to begin with but I failed to make a good note when removing them.
        Any pics of the top side of a 300 HP engine out there?
        • Harry S.
          • July 31, 2002
          • 5330
          Why not just post pictures of what you have?
          • Greg H.
            • June 2, 2008
            • 254
            Here it is
            • Bob R.
              • June 30, 2002
              • 1595
              3720 Carburator1.jpgI don't believe that part belongs on a 63 300 hp intake. I am posting an old picture of my intake
              • Timothy B.
                • April 30, 1983
                • 5196
                Greg, Bob,
                The clip does not belong on a 63 300 horse intake manifold but I believe it is correct for a 64 65 300hp manifold holding the PCV hose.
                Double check the AIM to be sure.
                • Greg H.
                  • June 2, 2008
                  • 254
                  Originally posted by Timothy Barbieri (6542)
                  Greg, Bob,
                  It is shown in my 1964 AIM. My problem is it is not that clear which bolt it is mounted to as it is existing from engine assembly. I think it is the forward bolt of the two center bolts as the other one I was told will hold the vacuum advance tube clip. I just want to be sure before I assemble them and touch up the paint.
                  • Jim D.
                    • 2885
                    That is correct.
