Re: Bubba at it again
Ed, The design leaves a space between them intentionally. Rushing air will still go up to the def vents. The space also allows removal of the pieces to prevent breakage, a common occurrence when the R & R'r takes things apart. The one below was like most. Very delicate. I use resin/mat to repair and sand smooth to recreate the flanges. I didn't have a photo of the final repair showing the result, but you can see a bit of it in the last photo.
This is a non C60 system but principle and spacing between the def vent and box is the same. It's the way it was designed. IIRC John H has a better picture.
