Mid years wiper grill nipple - NCRS Discussion Boards
  • Keith W.
    • June 30, 1998
    • 375
    Re: Mid years wiper grill nipple
    Wally , not aware of any comments that refer to it in the midyear juding books, however if it's agreed that it's on all mid years, would be worth adding on the next editions. If it's not there due to the paint guy just rubbing the lip down and not realising then Originally and condition have been changed / altered ? Just a thought
    • Al R.
      • June 30, 1988
      • 688
      WTH?, then, you see judges arguing over the size and general shape of it (after the body shops try to reproduce it) too large a height, too large a diameter, not shaped just quite right, location is approx. 1/64 off from where it should be and on and on. Can you imagine the dis-agreements and challenges on this one?
      • Harry S.
        • July 31, 2002
        • 5330
        I judge exterior, if I don't see it I just make a note to the owner. It's not enough to take a point or even make a mental DOT.
        If you saw one small chip in the fiberglass the same size as the bump would you take a point on the fiberglass line, I think not.
        • Keith W.
          • June 30, 1998
          • 375
          Al , Harry both good points - common sense wins again, I'll take that advice and just add note to the owner, if needs be.
          all the best Keith
