67 Brake pressure switch - NCRS Discussion Boards
  • Bill L.
    • April 1, 1985
    • 349
    HI:
    Back in June of this year there was a very long and informative thread regarding the rebuilding of a master cylinder and pressure switch for a 67 Corvette...
    One of the photos showed a part number on the pressure switch but some of the responses indicated that there were no numbers --
    The number is 2225781 ---- on two lines --- the front flat area has a "57" stamped into the body of the part --- there is also a "47" stamped in the bottom of the part toward the rear.
    Here is the photo from my 67 coupe ---
    The question is are these original switches?? I believe they are --- two sources of original parts have these exact parts with the same numbers in place being sold as cores ---for a 67 ---
    Thanks for any input ---
    Regards
    Bill
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11335
    Re: 67 Brake pressure switch
    Bill that was me....here.
    https://www.forums.ncrs.org/showthre...tch-Rebuilding
    A few years ago I had another....some pics. I think some numbser show up I'll let you look.
    PC230003.jpgPC230004.jpgPC250005.jpgPC250006.jpgPC250007.jpgPC250008.jpgPC250009.jpgPC250010.jpgPC250011.jpgPC260012.jpgPC260013.jpgPC260014.jpgpc260026.jpgPC260027.jpg
    • Bill L.
      • April 1, 1985
      • 349
      Yes Rich --- thanks!!
      That was great article --- and I noticed that you had a photo of the 22225781 pressure switch --- do you believe it to be an original?
      Thanks!!
      Bill
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11335
        Thanks!!
        Bill
        Yes Bill I believe it is, as well as the master cylinder which I had re-sleeved. The other one may have been replaced as I don't see the big 47 on top.
        • Jeffrey S.
          • April 1, 2004
          • 133
          HI:
          [ATTACH=CONFIG]64799[/ATTACH]
          Regards
          Bill
          I have one off my 67 coupe that looks like it has the 222# stamping on the side with the bolt ,on the opposite side is a very clear 43 stamping. I don't know if this is original or not,but the car has been off the road probably since the mid 70's so I think it could be original. Hopes this helps Jeff
