Suggestions for moving four post lifts - NCRS Discussion Boards
  • Roy S.
    Past National Judging Chairman
    • July 31, 1979
    • 1025
    I know this is not a Corvette technical question.
    I have two four post lifts that are probably Back Yard Buddy's which I bought about 26 years ago, I think they became Auto Lifters, they are very early models and do not have caster provisions or casters with them for easy mobility. I need to move these lifts to my shop at the house, I prefer not to disassemble them. I need suggestions for moving them. The base plates are 8' 6" at the widest point.
  • Jim D.
    • 2884
    Re: Suggestions for moving four post lifts
    How far is the move and over what type of terrain?
    • Roy S.
      • July 31, 1979
      • 1025
      Sorry, seventeen miles. will have to be loaded on something and unloaded, also will need to be mobile enough to get them moved out of one building and into position in another.
      • Mark D.
        1984-96 Team Leader
        • June 30, 1988
        • 2156
        Best way...
        Hire workers
        Go about your day, having lunch and a couple beers
        When workers are finished, stroke check and make dinner plans
        Kramden
        Kramden
        • Wally A.
          • May 31, 1979
          • 170
          pontoon boat trailer works great, raise the lift empty, slide to boat trailer under the lift and lower onto 4X4 cross ties. jack up
          posts and clamp, work great for me. good luck
          • Roy S.
            • July 31, 1979
            • 1025
            Best way...
            Hire workers
            Kramden
            Kramden, I probably should opt for your suggestions.
            • Roy S.
              • July 31, 1979
              • 1025
              I have yet to find a trailer I can rent that will fit between the posts, I'll check into a pontoon boat trailer. Thanks!
              • Mark T.
                • March 1, 2004
                • 199
                Roy the pontoon trailer is a good idea using the method we spoke about The lifts should weigh less than 2000 lbs each
                Mark
                • Mike M.
                  • May 31, 1974
                  • 8400
                  roy-boy. i bought a used 4 poster from a fellow MAC member when he moved to florida. took our rollback and a buddy. used the winch on rollback to get it on the bed. unloaded it with the john deere loader. mike
                  • Jim T.
                    • March 1, 1993
                    • 5351
                    Roy hope you post your method of moving your two lifts. I have two lifts like yours to move one day when I move from my current home.
                    • Ken R.
                      • August 31, 1980
                      • 308
                      Back when I lived in IN, companies would display fully assembled lifts at the INDY speedway meet. They would sell them on site so they didn't have to take back home. They did as mentioned above; backed a trailer under the raised lift. Lower the lift and raised the feet off the ground. Tied it down and hauled it to the buyer's house. Might not want to do it for across the USA but works for short hauls.
                      • Leif A.
                        • August 31, 1997
                        • 3643
                        Best way...
                        Hire workers
                        Kramden
                        I completely agree!! Roy, ask yourself what your time (and safety) are worth versus paying someone else to do the grunt work. I bet you can supervise the heck out of folks with a cold one in hand. Best of luck with the move.
                        Leif
                        • Gary J.
                          • April 1, 1980
                          • 1244
                          I would look into the companies that install lifts and I am sure they could move them. When they do get to your house be sure to expoy the anchors in.
                          • Enzo C.
                            • January 12, 2012
                            • 534
                            Hi Roy, I had 2 .... 4 post lifts moved this summer with in a 10 mile radius and it took 3 men one day and 600.00 per lift ... That's Canadian $$ ahhh
                            Enzo Colosimo
                            Ncrs Ontario Chapter Chairman 🇨🇦
                            ENZ-Z06/67
                            • Nick C.
                              • August 31, 1998
                              • 542
                              With all due respect, I'm not sure I would want to work under a 26 year old lift that was just uninstalled, moved 17 miles by one of unverified skill, and reinstalled.
