OK, I just read a long post put on C2 clutch problems and it was informative. However, it did not address the throw out bearing. Last night with the engine and transmission mostly put back together and in the car, I went to adjust the clutch linkage. Running the clevis all the way to the end of the clutch rod would not bring the throw out bearing in contact with the pressure plate fingers! After waiting for the "Blue Cloud" to disappear, all I could come up with was the throw out bearing disconnecting from the fork and sliding back against the front of the transmission.
Anyone else ever had this happen?
This is the one time I wish GM had made a removable inspection plate on the bottom of the bell housing. I have been so careful not to ding, or scratch the car, or the finish on the rebuilt engine, I hate the thought of having to unbolt everything and possibly remove the engine and transmission from the car.
Anyone know if it is possible to reinsert the throw out bearing into the fork, via the rubber boot hole where the fork goes through the bell housing?
Short of a major problem with the pressure plate, I can not think of any other reason for no clutch. The pressure plate looked fine when it was assembled out side the car.
Bill
Bill
