Differential bracket mount bolts, two or one castle nut bolts? (67) - NCRS Discussion Boards
  • Christopher T.
    • July 21, 2014
    • 6
    Hello,
    Confused on whether one or both bolts are of the castle nut/cotter pin variety?
    Chris
  • Gary R.
    • April 1, 1989
    • 1798
    Re: Differential bracket mount bolts, two or one castle nut bolts? (67)
    65-79 used the full length bolt. The 63-64 and some 65's used a small 7/16-14 bolt for the first hole. It was a weakness along with the steel bracket so the revision was to drill both thru and use the longer bolts, by 69 there was a reinforced bracket in use.
    • Wayne M.
      • March 1, 1980
      • 6414
      Here's a related technical bulletin. Interesting to note that they do not recommend drilling through the front bolt holes.
      c
      x
        • 43221
        c
        x
        Wayne-------
        It may be that the 63-E65 differential carrier casting would not support a through bolt at the forward location.
        • Leif A.
          • August 31, 1997
          • 3631
          Originally posted by Christopher Truett (60234)
          Hello,
          Chris
          Chris,
          Your title shows you're asking about a '67 but the picture you show is for a '63-'E65. See the pic below from the '67 AIM. Only the front bolt receives the cotter pin. The rear bolt receives a lock washer. Note the direction of insertion of each bolt, as well.
          Leif
            • 43221
            Originally posted by Leif Anderson (29632)
            Chris,
            Leif-------
            Yes, it was as you describe through 1968, at least as far as the AIM is concerned. However, it changed for 1969 and later when both bolts received SLOTTED NUTS (NOT castle nuts) and cotter pins. Could cars earlier than 1969 have received the same configuration? I tend to think so.
            • Leif A.
              • August 31, 1997
              • 3631
              Leif-------
              Joe,
              I agree completely with what you're saying. My point was the OP was asking about his "67 yet he was showing a diagram of a '63-'65E...didn't want him to get any more confused with information overload.
              Leif
              • Wayne M.
                • March 1, 1980
                • 6414
                here's my early '65 carrier (AP-9-17-64) with the forward threaded bolt holes (notice inspection paint dabs)
                c
                Last edited by Wayne M.; September 18, 2015, 07:42 AM. Reason: added year on assy date
                • Leif A.
                  • August 31, 1997
                  • 3631
                  Christopher,
                  Here is what you need for your '67.
                  Leif
