T3 Headlights - NCRS Discussion Boards
T3 Headlights
  • Morris R.
    • May 7, 2012
    • 213
    T3 Headlights
    I would like to replace my headlights with original T3 lights. My question is how difficult is it to install the T3's? Thank you
  • David K.
    • September 30, 1979
    • 241
    Re: T3 Headlights
    What year you working with ??
    • Paul S.
      • June 30, 1982
      • 359
      Re: T3 Headlights
      Take the screws out of bezal that goes around both lights ( should be 4 phillips screws ) now you can get at each bulb . There should be 3 screws around each bulb , remove them, pull bulb out , pull plug off the back of each bulb and swap the bulbs .
      • Kenneth B.
        • August 31, 1984
        • 2091
        Re: T3 Headlights
        You forgot to say which way to turn the screwdriver for each operation. Left out Right in. GOOD LUCK.
        • Morris R.
          • May 7, 2012
          • 213
          Re: T3 Headlights
          Thank you everyone!
          • Donald O.
            • May 31, 1990
            • 1593
            Re: T3 Headlights
            While the task is easy, my question to you is WHY?
            Unless the car is headed for the judging field, I would not used them. They will be dim, and likely yellow tinted from age. Use a set of new halogens for any night time driving.
            DonO
            • Gene M.
              • April 1, 1985
              • 4232
              Re: T3 Headlights
              Keep in mind you should NEVER check T3's direct off a car battery that is almost sure to blow them. Best to use about 9-10 volt reduced (resistor) source which is closer to realistic.
              Old T3's are prone to start smoking up after years and years of stowage. Careful prong insertion is advised to maintain the seal.
              • Mike M.
                • May 31, 1974
                • 8400
                Re: T3 Headlights
                i smear a thin film of silicone around the entry points on the back of the bulbs. if they leak(and suck in air), they die right now. mike
                  • 6950
                  Re: T3 Headlights
                  Or Ken its also lefty loosey, righty tighty.
                  • Kenneth B.
                    • August 31, 1984
                    • 2091
                    Re: T3 Headlights
                    You are right but since this is a technical discussion forum I thought I should use the technical wording to keep the high standard's of the forum.LOL
                    • Carl N.
                      • April 30, 1984
                      • 592
                      Re: T3 Headlights
                      Agree with DonO
                      If you are not having it judged and are going to drive it at night - use good halogens - at least on low beams
