Ive been happy ordering frame hardware through Paragon but they do not have the bolt that mounts the white pulley for the parking brake. Does anyone know a vendor who carries the correct bolt. The head marks show it to be a grade 5 with a letter "A". As for the pulley it is fine but is a tad yellowed. When new were they a true white? Thanks.
Looking for a vendor for 67' parking brake pulley and bolt
Tags: None
Re: Looking for a vendor for 67' parking brake pulley and bolt
Chris:
Try Long Island Corvette part # 51-97A (listed as a pair so not sure it is correct - but appears to be---they indicate 2" in length).
OR ---
Zip products has this:
It appears to be the part you need per their drawing... but check it out for yourself --- and --- I assume here that you know you need a spacer as well (if you don't already have one) ---- check out the parts in the '67 AIM UPC Section 5 C1.
I would not worry too much about the yellowing of the pulley --- it probably was white at one time but has discolored a bit. The one on my '67 is closer to white but it is new.
Hope this helps a bit ---
Regards
Bill- Top
Christopher-------
The original pulley was never completely white. It had a very slight yellowish "hue" to it.
The reproduction pulleys are WHITE-WHITE.In Appreciation of John Hinckley- Top
Thanks for the replies, I'll reuse the pulley and spacer. Still looking for the correct bolt. Is the bolt silver zinc plated?- Top
Christopher------
Bolt, nut, and spacer were phosphate-finished.In Appreciation of John Hinckley- Top
