Looking for a vendor for 67' parking brake pulley and bolt - NCRS Discussion Boards
  • Christopher T.
    • July 21, 2014
    • 6
    Ive been happy ordering frame hardware through Paragon but they do not have the bolt that mounts the white pulley for the parking brake. Does anyone know a vendor who carries the correct bolt. The head marks show it to be a grade 5 with a letter "A". As for the pulley it is fine but is a tad yellowed. When new were they a true white? Thanks.
  • Bill L.
    • April 1, 1985
    • 349
    Re: Looking for a vendor for 67' parking brake pulley and bolt
    Chris:
    Try Long Island Corvette part # 51-97A (listed as a pair so not sure it is correct - but appears to be---they indicate 2" in length).
    OR ---
    Zip products has this:
    It appears to be the part you need per their drawing... but check it out for yourself --- and --- I assume here that you know you need a spacer as well (if you don't already have one) ---- check out the parts in the '67 AIM UPC Section 5 C1.
    I would not worry too much about the yellowing of the pulley --- it probably was white at one time but has discolored a bit. The one on my '67 is closer to white but it is new.
    Hope this helps a bit ---
    Regards
    Bill
      • 43221
      Christopher-------
      The original pulley was never completely white. It had a very slight yellowish "hue" to it.
      The reproduction pulleys are WHITE-WHITE.
      • Keith B.
        • September 15, 2014
        • 1583
        the Bolt LIC sells is not correct, either in length or head mark
        • Christopher T.
          • July 21, 2014
          • 6
          Thanks for the replies, I'll reuse the pulley and spacer. Still looking for the correct bolt. Is the bolt silver zinc plated?
          • Gary B.
            • February 1, 1997
            • 7023
            You might check with Richard Fortier to see if he has the correct bolt. He advertises in the Driveline.
            Gary
              • 43221
              Christopher------
              Bolt, nut, and spacer were phosphate-finished.
